carthorse11
- Dec 19, 2023
good? Could you please tell me more how do you use it? Sorry I am new herevinegar mixed 50/50 with water
You soaked them in vinegar ?I have put the decals on my Lancaster using white vinegar mixed 50/50 with water and th wind line decals have gone all funny i will attach photos, is there anything I can do before I varnish
My thoughts exactly. All decals are usually soaked in water - not some crazy concoction of vinegar and acid.You soaked them in vinegar ?
5% diluted to 2.5% acetic acid ?
You probably removed the adhesive so it's not bonding .
Why did you soak them in that solution ?
Dont waste your time on that method. Hot or warm water is best and is readily available in your home.Hi @carthorse11 - is this
I just read somewhere that a lot of people use it ......obviousley not rightYou soaked them in vinegar ?
Im new here to and for godsake do not use it as it was a big mistakeHi @carthorse11 - is this
Never heard of that for fixing decals, definitely heading for trouble I think. I have always used micro sol and set after being advised to do so and in 2 year's I've never had an issue. PanthermanI have put the decals on my Lancaster using white vinegar mixed 50/50 with water and th wind line decals have gone all funny i will attach photos, is there anything I can do before I varnish
It's all a learning curb, so far I've snapped the canopy ( I hate painting canopies they are a nightmare) then the vinegar episode.
Hi, Momo, I hadn't forgotten this post.Please share that info IF you can find it .
I put Micro Sol and Mark Fit on baking soda and there was zero reaction . None .
I was never able to find any SDS or other info .
I have a couple of digital pH meters so I need do some more testing --- adding that to my list of things to do .
