USCM Sulaco
- Mar 22, 2015
Just getting back into modelling and I have a number of projects on the go, but in recently painting some resin castings I noted that when I used one of the AK pre made washes, the acrylic paint started to wear off. I always thought that white spirit and the pre made washes from AK and Mig Ammo and such would not disturb Acrylic paint as they are enamel based. Do I have this wrong? I want to be sure before I tackle some of the newly painted models.
I typically prime with AK acrylic primer and I typically paint with Vallejo Air Colors, AK, Mig Ammo or Tamiya paints. Everything is always cleaned, primed and allowed to dry at least for a week and days in between layers of paint.
Should I be clear coating these models with varnish before applying enamel based washes or filters or oil paint with white spirit? If so, what do you recommend? Some helpful hints would be appreciated. Thank you!
Also I have heard or read somewhere that enamel based washes and the Star Wars Bandai models do not get along so well...so before I try anything on my at-st, is there any suggestions here for this? Primed in Mig Ammo black primer and painted in Mig Ammo colors.
Again, any suggestions would be much appreciated.
Thanks very much!
Thanks very much!
