Misadventures with my Revell F-15E Strike Eagle 1:48
glennonrp
I decided I wanted to get back into this hobby. I built a few models as a kid and a few in college. So, my lovely wife bought me a couple kits for Christmas... And I bought some supplies. :) (I actually started with a build with my stepson of a Dodge Challenger... But, I like wings.)
I started the other day. I primed the kit and then started to carefully paint the cockpit. It came out decently. Luckily I watched a couple YouTube videos for some techniques on drybrushing the controls. Happy with that, I moved on to the landing gear and nose assembly. Small seams, but nothing frightening. Emboldened, I turned to the fuselage and wings. I had horrified memories of an F-14 kit years ago that had serious issues but this one came together nicely. I was feeling so good about it, I even decided to try to fill some seams with my newly purchased green putty and Mr. Surfacer.
Hit my first snag when I tried to decide if the seams on the wing tops were actually panel lines and should stay, or not. Had a lot of fun looking at f-15 pics on the Internet. I feel like the seams on the top of the wing should stay and the ones on the very front and where the wings meet the fuselage are the only things I should fill. Does that seem right?
Okay, I'm starting to feel like this kit is gonna have a lot of mistakes and I should consider it practice... And then I see something odd. At the back of the fuselage, where the horizontal stabilizers are, the very end of the plane, like the little pointy ends between the stabilizers, one is missing. It looks weird to me. But, I think it might be a space for another part. I go searching through the sprues and the instructions for the missing part. Then, I look more closely at the left horizontal stablizer, and I realize that part of it is missing.
Blast it, I see now that my top fuselage part is actually not fully formed. So, I've already put on the jet intakes, the conformal fuel tanks and the glue on the fuselage/wings cured days ago. I ordered a replacement part from Revell and used my hobby knife to carefully remove the top fuselage. Now I know this is a practice kit. I will get to practice sanding and filling and all kinds of techniques. But, I'm a little bummed because I was looking forward to finishing it.
Oh well, no worries. I am taking delivery on an airbrush, my first, later this month. So, this should the pressure off of me when I paint this one. Anyway, I thought maybe that since you guys all seem so good at this that you might get a chuckle from my noob misadventures. I'm sure there will be more.
Welcome back to the Hobby my friend, sounds like a fun return project. I'll be starting this same kit very soon. As a suggestion I would have waited for the replacement part, cleaned up the area around misformed place, ie; cut it back to where it was still good and then cut the corresponding part from the new to put back. No way would I try to cut apart the body after I had glued and sanded. I wish you luck with this project and wish many new adventures in the years to come.
Have a Model Day,
James
That's probably good advice. :) I will say, though, the left rear vertical stabilizer is part of the top fuselage. So, technically, all I did do was remove the badly formed part. If I removed only the stabilizer, I would have needed to saw it off of the fuselage. In any case, this kit is only $20, or less, and I was already thinking I would have to buy a new one before I saw Revell would replace the part. I am looking at the kit as a good learning experience. So far I learned to dry fit parts more carefully. Look at them more carefully. If I had noticed the malformed part earlier I could have just set this aside or something. A little thinking ahead here may have saved me some trouble.
I got an F/A-18 Super Hornet, also from Revell, so I may start that one in the mean time. Or, handpaint some of the smaller parts on the Eagle.
hey glennonrp, welcome to the forum and welcome back to the hobby. I too am just getting into the wings. I am building my first one. Good luck, have fun.
Hi Adam, thanks! I just was working on sanding the nose, painting the landing gear, and putting together some of the armaments. Thanks for the welcome. :)
Welcome back to the hobby and good luck with your build!
My fav plane, looking forward to seeing it.
