My first scratchbuilt building using a cardboard box
Kiwi
Hi everyone. It's been a long time I posted here.
A few weeks ago, I was looking to my recycle bin and I took a little cardboard box from Amazon. I decided to make some tests, to see if I could build something that would look cool. I was especially interested in building my first 6mm building for my future 6mm wargaming terrain.
So I start building a block. Right at the beginning, I decided to add lots of little debris inside the building to make it look like a ruin building from World War II. After painting those debris, I was very happy with the result. So I decided to build the exterior. Inside the building, the first roof would be ideal for placing some soldiers.
- I carved the windows.
- I carved the cardboard walls to make it look like brick walls.
- I destructed some windows and cut pieces from the roof so it looks like the building was bombed
- I glued the building on a balsa wood piece.
- I added lot more debris agains the outside walls.
My job is not done yet. I still have to do these thing;
- Make sure the balsa wood base is flat on the ground (it's not).
- Correct the door entrance because I don't like the way it looks.
- Add lots of smaller rectangular debris on the top of the outside debris to make it looks like bricks.
- Add one or two layers of black primer on the outside debris.
- Paint the debris pile.
- Add some variation of colors on the walls. The varnish layer I added made all the colors blend it so I must add more brick colors.
Any tips or suggestions to help me improve this building?
