Good afternoon to you all,
Well, this is an almost ludic project that I decided to carry on a year ago or so… after my return to modelling. I also thought that it would be a good training, a kind of calisthenics with new (for me) techniques and materials: PE parts, aftermarket parts, use of evergreen, cutting pieces of the model, employing working tracks (Modelkasten), filters, etc, etc… well, you know, all that kind of stuff that was inexistent back in the 80´s or at least unbeknown to me.
I can remember watching the Tamiya catalog back in 1983 … an also watching with amazement a Verlinden´s diorama book in 1985… I always had some kind of Freudian fixation with the SU-122 (I don´t know why), so I decided to take one of this relics (the model was made back in the late 60´s or early 70´s, I don´t know well this detail), and optimistically to try to “improve†visually this design and get a less monotone and anodine model.
Reading a bit about Finnish T-34s (captured ones or the ones bought to Germany) and about Stug III (also in Finnish service), I decided that it could have been feasible that some SU-122 could have seen service in the Finnish assault guns batts.
So I decided to make some little “improvements†in the model (“Finnish†improvements), that could be summarized in:
• up-armoring the front of the vehicle, with welded Ekranamy-style 30 mm armor plates, and.
• Adding side spare-supplies boxes.
I have found a lot of deficiencies in the kit, some of them outrageous (like the absence of the rear-facing little hatch in the left positioned observation hull top cupola), but I think I´ve advanced a lot. The work is not finished by now, and I´ve advanced a bit more in weathering (slightly mudding and dusting) the bogies and lower part of the hull…
Let me show you some photos of this intensive self-learning project /sparring model. I repeat: this model is still very far from being finished, guys.
I have used:
• The old, very old Tamiya SU-122 1:35. A relic.
• Eduard PE kit : I´ve used only a part of it, I cannot say it has a great quality.
• Eduard SU-122 barrel: really BAD. I´ve had to enlarge manually the diameter of the bore, because the original one would have worked well… for a 76 mm gun…
• Eureka towing cables (very nice)
• Modelkasten tracks (very, very nice, beautiful… and very, very fragile!)
• Lots of evergreen, lots I say.
• Royal Model T-34/SU-122 fuel drums (fantastic ones)
• And I have a set of Sturmi decals Reddy to use with this model (Echelon, if I´m not wrong now!)
And I must recognize that maybe I´ve been a little “artistic†in the painting… but that doesn´t takes my sleep out!
(hush: I can see a piece of Kleenex paper inside the bore of the gun: by the time of this message, it has been cruelly deported to the waste bin)
Eduard PE kit:
The Modelkasten tracks:
The Royal Model fuel drums:
“Botox†stage:
After the “basic†painting: in my (what you call) “man â€"modelling- caveâ€â€¦
Some close ups: I can see deficiencies. Those photos are useful… mmm…
And these are the photos that I’ve by now, although I’ve advanced with the lower hull, bogies, etc, a lot…
I know that the model is not a winner, but I´m enjoying it a lot.
Cheers/saludos, guys.
I have used:
Eduard PE kit:
“Botox†stage:
