ulvdemon
- Jul 16, 2012
I am using a Badger 180-1 with a paasche H single action airbrush. The regulator is a Master airbrush model (which i can not recall the model at this time). I had the chance to assemble everything and run it for the first time on Saturday. It worked well once I turned up past 30 psi. Under that, I am not getting any air it seems coming through the line to spray. The paint I am using is Model master acrylics. Has anyoen encountered something liek this? The only thing I can think of is I need to add more thinner to the paint, so I will give that a try. Any other suggestions on how to troubleshoot would be appreciated. Thank you.
