Part scratch build of R/C HMS NORFOLK TYPE 23 FRIGATE F230 in 1/72 SCALE
BOATMAN
HI ALL well Down time said he would like to see my builds on here with lots of pics so here we go with a near full build an this ship took me 3 yrs to build as i bought a
GF HULL from Fleet scale An here is the full 6 ft hull an its a qick build for me as saves building the hull WILLpost more pics later as ive found that a lot of the pics are still imn m/b size so i will have to resize them before i can show this build
chrisb
An when fittin the hull jiont ive fitted a bit of plasti card the thickness on a hack saw blade so when the jiont is gluded in the hull i then remove the bolts an then the plasticard so i can get in a hack saw blade to cut the hull in half an here cuttin the hull IMG_4330.JPG
AN when painted black i get this an the bolts are fitted in an they slide throegh brass slevess so the holes dont wear big an this is the finished hul jiont with the eletric plug connections front part of the hull IMG_3975.JPG
An the stern section also fitted with the eletric plugs fitted so both parts of the hull just slide into each other an then to hold it togeather there are butterfly nuts to pull the hulls togeather an water tight
well that will do for now if there is an intrest in the build from members then i'll carry on posting the build
AN HERE the main power wires in their sockets an they meet up ok to carry power to the twin motors when they are fitted an the top computer plug also meets up ok an there will be 24 thin wires to carry power to the servos an lights an such IMG_4345.JPG
an i wanted a smoke unit fitted but it was very awkward to fit as it pipe from the unit had to be a Z bend TO fit up to where the funnel would be an there is a metal grill fitted on the deck for the smoke unit to suck air in down to the smoke unit fan to help push out the water smoke IMG_4354.JPG
