Tanker52
- Mar 21, 2011
T-70 Light Tank 1/35 scale by Techmod. The kit goes together well with some fit issue on the underside of the turret. You will not see once the turret is fitted. Some of the details are soft but overall a good kit for a weekend build. I did make some changes to the kit parts.
I used some tubing to replace the main gun and the machine gun. I used some copper wire to create new grab handles.
I did not like how the idler wheel attached to the kit. Since the kit has individual track links, I wanted to be able to position the idler wheel once the tracks are installed. So what I did is cut a piece of brass tubing so the idler wheel shaft fits snuggly and this will allow me to rotate to the proper position.
