Elm City Hobbies
- May 7, 2009
Promised myself that I wouldn't start anything else new until I finished something. So much for that one, this was just calling to me.
Takom T-54B, going to be doing it in the '73 Egyptian markings included in the kit.
Since Takom uses a common lower hull for all of their T-54/55/Type 69 kits, some surgery was needed, and holes filled to make this version.
Kit comes with both the Star pattern and Spider pattern wheels, so going to use a mix of them on this kit.
Top plate on the chassis. While it fits (mostly), it isn't a drop in fit, so some care needs to be taken to get everything lined up correctly. Once everything else is installed to it, you won't see the slight overhang on the front right.
