Here's a different form of modelling that you rarely see today, 100% scratchbuilt, that's hand making EVERYTHING.
So NO kit bits AT ALL, you just use your hands and use different tooling to create what you want, start with a slab of timber and go for it.
Here's a Low Set Milk Cart I made from using a drawing printed in "The Australasian Coachbuilder and Saddler, June of 1899.
This drawing would be used by a Wainwright to build a full sized vehicle, so why not use the exact same drawing to make a model.
By using the original drawing for the model, kind of puts the model into the 100% Historically Accurately catergory.
The drawing shows where every nut and bolt should go and all nuts and bolts are made by myself as well.
Very rarely do I use any store bought nuts and bolts, I try to make them all myself.
It's a far cry from any model kit on the market, that uses the same terminology as being 'hysterically accurate' ( NOT ).
The wooden spoked wheels have 'dish' built into them, the axle's even have a 'set' to it as well, to give a 'plumb spoke' when fitted to the model.
OK, enough rambling, have a look and let me know what you think of this sort of modelling.
