Canopy glue?
BTW , I store PVA containers inverted and rotate them upright every couple of days , back and forth , to keep the solids in even suspension .
I started doing that when I grabbed a bottle of Elmers and the business end was mostly water .
It was a small , sloppy test but from the margin in those values , I believe we can safely say the Canopy Glue has better adhesion on plastic .
EDIT : I'm thinking for that tension test labeled #3 , the plastic disk may have had a contaminate on it since the Canopy Glue was able to resist considerably less force than the other examples and those were 2 mm test pieces .
You'd expect a stronger joint from more glue area .
Like I said , it was a sloppy test .
I didn't do a lot of prep , just ran a bead of glue and set them in place .
