blakeh1
- Oct 26, 2011
This is the Italeri kit representing the gulf war
Unless I am mistaken, the color scheme for the low vis of these jets is Dark Ghost Grey and Light Ghost Grey
I used Vallejo Model Air 711120/FS36320 Dark Ghost grey
However, the decals in the Italeri kit are a near perfect color match and disappear on the Ghost Grey??
I would think they should be a bit darker at the very least
Is it possible that the colors on the decals are off due to a printing problem, or should I be using a different color?
In my experience, Italeri decals are good quality, and from what I can tell the high vis decals on the sheet look perfect color wise so it does not seem like a mistake
NOTE - the color in this pic is muck darker than it appears in person
This is not my image, but it shows the Vallejo Ghost Grey next to a FS36320 sample and the colors are close, and in fact, the Vallejo Ghost grey a bit lighter even
This is not my build or pic, but it is the same kit, and looks like they used the kit decals. You can barely see them and they are actually lighter than the paint
this is how it appears in the kit instructions
I used the same paint colors on my 1/72 F-18C from Hasegawa and the low vis decals contrast/darkness seems ok
color is identical to the one used on the A-6
Although I do notice in the instructions, it says FS35237 as to what they call "Dark Ghost Grey" which is a similar darkness/shade, but slightly more blue according to the Vallejo Model air paints. I have. IN fact, I painted a bit of that color onto the top of the engine exhaust and it is hard to see much of a color difference so even if I used that color it would be the same issue
So do I lighten the color with some white, or are the marking really supposed to be as light or lighter than the body color
Or look for aftermarket decals?
I also noticed when building a High Vis scheme, they did not call for Light Gull Grey (16440/36440) which I thought was typical of high vis, but instead listed Flat Gull Grey (36622)
How accurate is Italeri with color suggestions?
