J John T. New Member Joined Nov 8, 2023 Messages 7 Nov 8, 2023 #1 Does anyone how to install the tires on with out the pins in the brake drums?
urumomo Well-Known Member Joined Mar 18, 2013 Messages 6,820 Nov 8, 2023 #2 Welcome to the site , can you give us some specifics ? What kit ?
urumomo Well-Known Member Joined Mar 18, 2013 Messages 6,820 Nov 8, 2023 #5 Is it one of these kits ? : https://www.scalemates.com/search.php?fkSECTION[]=All&q=Revell+1930+Model+A* I can't find instructions for them , Could you post a photo or two of what we're talking about ?
urumomo Well-Known Member Joined Mar 18, 2013 Messages 6,820 Nov 8, 2023 #8 OK , I found the instructions for a similar kit . Open this ---- > https://www.scalemates.com/products/img/0/3/6/946036-63-instructions.pdf On step 7 , is that the pin you're talking about ? If so , you can use some plastic rod to replace it if missing .
urumomo Well-Known Member Joined Mar 18, 2013 Messages 6,820 Nov 8, 2023 #9 This page has the Model A ---- > https://www.manualslib.com/manual/586484/Revell-Kit-4242.html ... I had to get the farm started here but now I have some time to search ,
J John T. New Member Joined Nov 8, 2023 Messages 7 Nov 8, 2023 #10 THKS. Look at no 7and 8 my tires wil not stay on with the pin in them.
urumomo Well-Known Member Joined Mar 18, 2013 Messages 6,820 Nov 8, 2023 #11 Ah , so you have the pins , Did you glue them into the axles ?
Pantherman Well-Known Member Joined Feb 10, 2022 Messages 3,312 Nov 8, 2023 #12 John T. said: Does anyone how to install the tires on with out the pins in the brake drums? Click to expand... Hi and welcome to the forum. Can you post photos of the issue as that will help us see the problem. Pantherman
S scalebuilderchad Active Member Joined Aug 31, 2023 Messages 174 Nov 14, 2023 #13 What glue are you using? Regular model glue will not hold those metal pins in the axle. You have to use a CA glue (super glue).
