GaryG64
- Sep 8, 2022
Thanks. PM
I had the same problem with the typhoon, used several washes of alcohol which loosened some of the glue. Had to gently get a blade into the joint in the end, some came away with the pins intact but others broke off so I took photos to remind me of what went where. PanthermanI need_want to remove the bomb hanger and the fuel tank, but since it's been 27 years I cannot remember if it's Testors glue or super glue.
Any suggestions?
Alcohol? Thanks, I'll give it a try.I had the same problem with the typhoon, used several washes of alcohol which loosened some of the glue. Had to gently get a blade into the joint in the end, some came away with the pins intact but others broke off so I took photos to remind me of what went where. Pantherman
Be aware that it will also strip the paint very quickly. PanthermanAlcohol? Thanks, I'll give it a try.
That's OK I'm going to repaint the whole thing.Be aware that it will also strip the paint very quickly. Pantherman
It's looking soooooooooo much better, nice one. PanthermanSlow but steady. I've stripped most of the parts off – landing gear, pilot, bombardier, seats, etc.
I removed all of the masking tape to check for leaks, and there are a few here and there to touch-up.
Thank you.It's looking soooooooooo much better, nice one. Pantherman
