Absolutely! I need to pick up some cellulose thinner to try for cleaning. I've used Model Masters thinner, and rubbing alcohol to thin Tamiya paints, but their lacquer thinner makes their acrylics spray/lay my favorite way so far. (and while the Tamiya Lacquer thinner doesn't make it very shelf stable, it does work for spraying Mr. Hobby Lacquers)
You can mix and match chemicals, but I've found I get the most consistent and quality results (the first time, or close too) by using add-ins designed by the same company that makes the paint... or at least designed to be used with a specific paint. And NOT having to strip things to redo them, as well as NOT having to do more than thinning a paint for pigment prep, is worth it to me. But that is intrinsic value, every one has their own means and assigns their own worth to what they buy/use.
I'll spend a bit more coin to spend more time doing, and less time prepping, fixing, and making work arounds any day.
Follow up, is this the thinner you use, and if so, do you use it with Tamiya Acrylic? Or Something else?
