Bronco Buffalo MPCV " BoneCrusher"
alerama7 said:
a query, the alclad for glasses, is applied with a solvent in the airbrush.? or pure.? that measures should I use.?
Thank´s
I sprayed it pure in very very thin mist coats to build up the color. I masked the exterior surface so it'd be glossy on the outside. Also, put a white piece of paper under to see just how much you're putting down. GOOD LUCK !
TBadger said:
Thank´s
excellent, thank you very much, I will ..!!
Ok, I missed this one, ooops. What a beast, awesome work Badg, awesome! I'll bet you were ready to pull teeth after the PE parts. Bravo!
Cheers, Ski.
