Christine engine
briantammy93
New here. Hello everyone. Im looking for and aftermarket engine for AMT Christine. The engine isn't accurate in the box. Does anyone know where I can pick up an aftermarket engine or a kit that has the correct engine in it?
Thank you all
Brian
There is an early Hemi in the '57 300 kit. (392 ?)
And the Moebius '55 has a Hemi it.
Can't speak about the Moebius '56 300B.
If you can duplicate the parts and they fit from the '57, you won't waste a kit for a partial engine.
A "Hemi" is not accurate to this car.
In the 50s, "Hemis" were not the big block high performance engines found in late 60s/70s muscle cars.
They were just better performing engines.
The first Chrysler Hemi offered (in a car) was a V6.
I'm not a huge fan of the Christine movie, but I love movie cars and their history.
So I did a little research.
The engine in the AMT kit looks like a small block V8 (accurate)
however the single air filter housing would be incorrect since it was a twin carb setup.
It should have two oval air cleaners.
In the Stephen King book, Christine was a 1958 Plymouth Fury 4-door.
However, the Fury did not come as a 4-door.
In the film, the car became a 2-door, obviously.
However, of the 24 cars acquired for the movie, only one was a Fury.
The rest were Savoys and Belvederes (pretty much the same car).
Engine options for the 1958 Fury were:
318 twin 4bbl V8,
350 twin 4bbl Golden Commando V8 (popular choice)
or the 350 big block V8 with Electronic Fuel Injection.
The Belvedere (and Savoy) models came with both 6 and 8 cylinder options,
ranging from 230 inline 6 to a 350 V8 with single 4bbl carb.
According to the Peterson Automotive Museum (where the alleged Christine Fury is now)
the engine is the small block 318 V8 with twin 4bbl carbs.
So you should only need to modify the air cleaners.
Thank you for this information. Ill take a look.
Brian, this might have been a better choice of options. I got lazy.
Thanks to AirDave for his better explanation.
The first, left to right, is the AMT '57 300,
AMT '57 Belvedere and the Moebius'56 300
Really cool kits if you ask me.
I am under the impression that the '55 and '56 Moebius kits are similar.
My opinion would be the AMT 300 in the Christine. I'm assuming the cross kit would be simple enough. The twin oval air cleaners are just BOSS and most people don't know what they're looking at anyway.
Thank you all. The real problem is the air cleaners. I'm pretty sure the Christine car used a 350 commando engine. The twin intake and carbs the easy part. I could probably use the air cleaners from the 67 300 just set them on top of carbs not on their side. Ill need to put the distributor on the front but thats not a big deal. Valve covers say 350 and I'm sure I read it was a commando. 1970 Mustang 428 Super Cobra Jet engine sound was used in the movie as Christine didn't sound menacing enough.
That AMT 57 Chrysler 300C would be a good 'un, but the cleaner lids aren't chrome in the kit. You could bare metal foil 'em?
Rob.
I've been looking and it seems to be one of the only times it's been sorta kitted.
I say that knowing I gave up pretty quickly. Several things showed up in the search and I got lead off in all kinda other directions and forgot what I was even looking for.
I apologize.
Rob.
