French FT-17 1/35 Meng Kit
MystRacing
I'm continuing my WW1 Armor kick I've been on and decided to post this next build. I kind of speed built the other 2 french tanks I did. The St. Chamond and Schnieder. When I signed up for this site I mentioned wanting to get better with PE and this is one of the kits I bought with that in mind. I have the Meng FT-17 Cast Turret full interior kit. I also bought an Eduard PE set with a lot of little details and the rear skid assembly, a Voyager Model set of PE Tracks, and I had an Aber barrel. I ordered some figures of French soldiers doing maintenance and some other resin items to make a small diorama of the tank being maintained. Here are all the parts.
I don't normally buy kits with full interiors because of the obvious issue of not being able to see much of the interior without building it so you can take it apart. However, one really cool thing about this tank is it's so small about 80% of the interior can be seen when the hatches are open without disassembling the tank.
The basic kit is pretty typical of a modern plastic kit so I'm not going to go into a ton of detail here. It comes with 4 different paint schemes, the one not shown is a german grey captured version. The FT-17 was the first tank in a typical modern configuration and used during and shortly after WW1 but 27 different countries. Versions of it were even built in different countries like the US and Russia. About any color scheme you could think up is out there.
It also comes with a little bit of its own PE and some metal springs and rods for the working suspension. I've alway thought something like this was a little toyish and king of silly on a static model, but each to there own I guess.
The first three steps of the instructions have you build the transmission and engine. The two items are made up of 45 different parts, but I have to say I was really impressed with how well it all goes together. Given the number of little parts I have to give meng an A++ for the layout of locating pins etc, it was remarkably easy to assemble. I painted it in assemblies as I went along like is typical for a kit with an interior. Here's the work after the first day. I spent about 6 hours getting to this point. After some more studying of the instructions, the transmission and the fuel tank will be completely hidden. The rest of the interior stuff should be visible.
Then last night I spent about an hour and a half and added the final linkages and lines to the engine. I took some liberties with the colors to make it look the way I wanted it too. I made some wires fron the magneto to the spark plugs from magnet wire. It's amazing the magnet wires look oversized, but I'm happy with it.
As all of you know who post on here, it looks better i person. There's nothing better than a good macro photo to show every flaw.
And finally, here is the view of the motor that I expect will be visible when it's in the tank.
I really like it, loving the details. Pantherman
I've managed to do a little work on this in the last week. I finished the floor and got the driving controls and seat in place. Spent a bunch of time last weekend with scrap PE and I'm starting to think the more complicated PE stuff is just too time consuming for a marginal improvement in appearance. Particularly if you have to get out a magnifying glass and pint it out for somebody to see it. At any rate here's my floor pan with the motor etc. mounted.
I've never touched a kit from Meng, but looking at the instructions on scalemates, I'm impressed. Threads like this only make me more interested. How hard is it to get these in late 2024, current situation and what not?
Edbert - I bought mine from Aliexpress which usually means at least a couple weeks shipping time but stuff eventually shows up. Andys HHQ had the riveted turret version in stock, they're also available on Amazon. I haven't had any trouble finding the Meng kits in general I have several others.
I finished assembling the interior. I'm going to add some weathering with a wash and some pastels to tone down the shine, but I'm really happy with it. It took some work to get the sides in place. As usual the paint along the seams even after being scraped caused it to be a little hard to get the sides to adhere, but attaching the little end plates that were clean really helped. The rack on the left side is full of the little 37mm cannon shells it fired. The gas tank completely covers the transmission, the only visible part is the pulley with the crank on the back wall of the turret area.
I probably should have researched this instead of just following the instructions but thought it would look nice. That being said I think the black disk looking things are magazines for a Vickers machine gun. Some FT-17s had a 37mm canon and some had a Vickers machine gun in the turret. they didn't have both so it seems odd there would be storage racks for the machine gun ammo on one side and the canon on the other if there wasn't a machine gun. I might also be wrong about what the disks are. The kit comes with both so you can build it either way.
I'm planning on building the outside unpainted with the doors temporarily closed and then paint the outside, after which I can open all the hatches. I haven't done this before myself, so it'll be interesting to see how it works.
Haven't done an update on this in a while because I haven't done much with it, but it is still coming along slowly. I did manage to mount some of the exterior details and then add the panels to close the top minus the parts that will remain open and the turret.
And here is with the top on. Had to use a little putty i just couldn't get the seams to totally close up.
Here it is with my type 82 staff car (VW Bug) for a size reference. Pretty small for a tank for sure.
This kit comes with three options for weapons in the turret either a Vickers Machine Gun, a 37mm canon, or the M1914 Hotchkiss machine gun below. Kind of nice touch that Meng included a tripod for the Hotchkiss if you don't want to use it in the tank. The barrel is an Aber product. The kit also has six of the little boxes with a crank on the side. I have no clue what those are. They are in the same step as building the machine gun. Could be ammo but it's odd given the Hotchkiss used a long flat plate sort of thing to hold ammo for shooting and it wouldn't fit in the box.
I've been spending a lot of time on another 1/35 model, but don't want to post it until I have a better feeling of if it'll be successful or not. Either way I should be back to this more steadily in a few weeks.
I think you're probably right about the black disks being ammo drums.
Your thread caused me to add a few kits to my wish list, There are 1/16 version of the FT. Since it is so small, I think my cabinet can hold it.
I'm also building my first ever Meng kit, I'm pretty impressed so far.
Oh ya, sign me up!
I knew I'd seen it in reading...
WW2 North Africa
the FT-17 was exported to numerous different countries and France itself maintained about eight tank battalions with the FT-17 to make a total of 1,300 FTs by 1940. After France had fallen, some were used by other countries, some were used by Vichy France in North Africa... according to post in Fandom WW2 Wiki
Well, I have been doing some modelling the past 6 months I just got sidetracked and didn't update any of the threads. Being as I'm about to get parts to move forward on my Knox I decided I should update this as well.
I completed the basic assembly of this to the point of doing the tracks and everything was pretty straight forward.
At this point it was time to work on the tracks. I had purchased a set of PE tracks for it but after looking at the assembly instructions realized it just was not something I was going to do. The included snap together tracks are pretty nice and only took about a half hour to assemble. I think the PE tracks would have taken a half hour per link. Here's a peek at the instructions. Certainly, way more than I want to do.
I then tack glued with some PVA the doors that were to be posed open when finished. And painted the camo without the tracks on. I used the masking putty for Andy's HHQ, it's probably the same thing as the AK masking putty to do the camo. And snapped the tracks in place. Then opened up the hatches again.
Next I painted the details like the exhaust and canvas on the rear etc. and did some weathering. I placed the figure in just for refrence to the size of the FT17. This is actually a British WW1 Soldier.
If I did a last critique of this kit I would say I definitely recommend it. The only thing you really have to look out for is making sure all the panels line up that make up the upper hull. It's one of those kits where you'll want to assemble the upper hull kind of all at once and place the top cover on it loose just to make sure everything is lined up correct. If you just glue a couple of the hull pieces together at a time and let it dry there's a good chance it won't be lined up correctly when it's time to put the top on.
I think my next craze will be North Africa Free and Vichy French.
Great job on interior fer sure, and like how you handled the tracks!
Interesting how they added that tail skid for stability and help crossing ditches/trenches.
Funny you should mention north Africa. While I was waiting on my Knox parts to be printed. I tested out the MIG Atom paints and a new to me method for creating heavy desert weathering. I built this as a load for a Scammel Tank Transporter (Lybia 1942) I plan on doing in a North Africa theme. The idea is that this is just really dirt from months in the desert and being moved to a new area. The dirt is heavily diluted paint with pigment mixed in it. Most of the typical methods look like light colored mud instead of just dirt buildup. I really like this effect for a semi arid desert region.
Nice! There were so many different conditions and environments in North Africa, especially if you include everything from Morocco to East Africa!
Virtually all of my builds are focussed on that part of the WW2 world, up into Palestine and hopefully Malta. I like how that looks, and the technique sounds relatively straightforward to do.
I've also got a Scammel in the stash: the Pioneer heavy artillery tractor.
Cheers!
