I have been working with 9V with my current build and I am using 390 ohm for red, yellow, orange and 330 ohm for white, blue, green. That is what the on line calculator says.
I think that calculator is a bit conservative. When I do the math by hand, at 9V, I get the resistance is 290 ohms. It is reporting back 330 because that is a common resistor which you can buy almost anywhere. 300 ohms is not common and is hard to find.
I found another site that gives more information:
http://www.hebeiltd.com.cn/?p=zz.led.resistor.calculator
It says for white LED's at 9V you need a 290 ohm resistor.
If you use a lower value to the resistor, the LED will be brighter, and it will not last as long. This is because the resistor is feeding the LED too much energy. The extra energy will allow it to be brighter, and burn it up at the same time.
If you use too high of a resistor, it will supply the LED with not enough power, making it a bit dimmer and extending it's life. The LED wizard just makes sure you don't burn up your LED's.
Last night I was soldering a 330 ohm resistor to a SMD LED, and when I was done I put it on a 3V power supply. It still lights up, but pretty dim. So too much resistance will work. Not enough will not.
Hope this helps!
