More of the dio.
Painted the cobbles and pavements a base colour of black and started to dry brush many, many greys and browns.
Started to paint the buildings, I'm about 1/2 way there. Added a light coating of mud to the road, but more on that later. Added some still water to the gutters, most of which will be covered with debris and mud.
Started to add some wall paper to the upstairs and stain the steps on the stairs, added white gloss to the woodwork, still to add loads to the inside of this building.
Used small corrigated cardboard with the paper outer stripped to represent corrigated iron sheets for the roof of the small garage, painted black and then rust colour.
Using more balsa wood to create a damaged roof for the two storey building (not finished yet).
My rubble which is a mix of home made bricks and blocks, sand and cat litter, loads of other items will be added to this, wood, roof tiles, damaged sections of brick walls, etc, etc.
Been experimenting with mud and just about got it right , which do you prefer? The dio will portray a wet/damp day in early December 1944.
Thanks for looking Joolz. ;D
More later.
