KRIEG ADLER
I hope I did not miss the post where you said that but what is the wire you use to make these grey tubes?
the Baron said:
The guns look fantastic in place!
I was wondering if you considered using brass tubing, instead of styrene, for strength. But I guess in this application, the plastic tubing is strong enough, in this short length.
Thanks! I just used what I had on hand. When I get the inspiration it best for me to build it as soon as possible. :D
8)
They are made from solder wire. .055" wrapped with .015" dia. wire. I used solder because it easy to shape and bend.
Terry 8)
If you thought this had gone away. Well......you would be WRONG!!!!
I have been working on the lift engines. It's kinda like working on road wheels doing the same thing over and over.
Next I am in the process of replacing the kit parts with something a little real looking.
More coming.
Terry 8)
Ok here is first engine assembly! Still have some details to add, but you will get the gist of the other three.
You are about to say how are you going paint that stuff? Well......
Terry 8)
Quaralane said:
Looking good, Terry
Thanks Q!
There comes a time in every models life when painting has to happen. I added the first painting steps and attached the main engines.
Terry
Wow man this is awesome! Love all the great mod work, the paint looks killer too!
I decided to get the guns mounted, but first I added some spaced armor.
Terry
