My Mk 42 Iron man is delayed due to some mixup by the supplier from Asia... Which means I won't get it till after my vacation in July, ohh well.
In the meantime my other kits have shown up, and I'll be going through them in some detail while I wait for my mk 42 kit.
I got the retooled mk III kit from Moebius and War Machine, also from Moebius.
Let's take a look at the mk III kit first:
The box is pretty standard for a plastic kit, it comes with all the parts moulded in a shiny red styrene, boxart is good, but not as great as on the Iron Man 2 kits.
You get 4 frames, it's a pretty simple kit with very little flash.
The base comes seperate, and honestly looks awful if I have to be honest, so I won't be using that.
Overall it looks reasonable, and I got it for £9.99 so I'm not complaining, if you have to pay full retail however I'd think twice before buying it as the mk VI kit they do is a lot better.
Here's a comparison shot of the 2 kits, the mk III have just been snapped together, nothing fancy.
They are supposed both in 1/8 scale but the mk III kit is somewhat smaller.
Also worth noticing is that the detail on the mk III is a lot softer than the mk VI kit. Now granted the mk III design is a much more curvy design, the parts that should have sharp edges on detail like the helmet is all bland and not very well defined which they all are on the mk VI kit.
The pose on the retooled version is an improvement from the original kit they did but it's still a bit off, the IM 2 kits are better posed than this is.
The base is... well I won't say that here, let's just say that I will not use it, ever.
If you're willing to live with these imperfections I think it's definitely worth buying the kit, as it is Iron Man after all and it's still a decent model seeing as it's obvious from their never Iron Man kits that they have improved their design phase vastly since this was originally designed.
Now if you're like me, and can't live with the imperfections but still want a nice looking mk III iron man kit there's nothing else to do than to fix the kit
Now begins the fun part
I have decided that on top of fixing the bland details this will also be my testpiece for lighting it, for when the MK 42 kit arrives. For this I needed to hollow out the eyes as they are moulded onto the faceplate unlike the mk VI and War Machine kit where they are separate pieces.
Then I cut the face plate free, and mounted the bottom piece on the helmet I also removed the positioning struts. The now eyeless faceplate needed some eye lenses, these were made by heating some leftover clear styrene sprue from a cockpit over an open flame, then pressing it lightly into the eye socket from inside the face plate with a rounded object. This gave a nice curved indent for the LED's to fit into. Then I superglued the LED's in place and tested them.
I used a file and some different grades of sandpaper to redefine the detail on the face plate and helmet, then I airbrushed the face plate with Vallejo Model Air (VMA for short) gold and VMA brass. Painted the black line in around his eyes and mounted the lenses, then I painted the inside of the face plate with VMA silver to contain the light to the eyes.
The helmet had most of it's underlying "facial" structure removed to make space for the LED's.
I also drilled out the screws on the faceplate, and will add the ones I forgot.
So far this is going well, I'll likely end up reposing the kit entirely, a I am really not happy with the pose.
Comments and criticism are welcome
