vadersrighthand
- Feb 7, 2012
OK, first post here so please be gentle. I've performed many searches on this subject watched a ton of yootoob videos, read many articles and tips already, but am struggling with doing my panel lines, its on my first model back after not doing any since i was a teenager. So onto the questions, hopefully these will help some other beginners.
The model i am working on is a Tamiya p51 mustang (Petie 2nd), much as i'd like to say i went for a NMF i didn't, just coated the model in flat aluminium - I'm still learning...
I've painted everything and have applied 2 gloss coats (one prior to decals, which was a Humbrol Rattle Can, the second was a Vallejo Gloss Varnish, using a brush to paint it on) BTW no airbrushes yet.
So far so good, brush finish isn't as nice as i'd hoped but it'll do for my first model back.
So i got myself a set of the Vallejo Washes and will be using those for my panel lines.
My issues start now, I'm only working on the underside of the tail plane as that area is sort of hidden from view most of the time...
1, first attempt, i carefully filled the lines with diluted wash (being careful) about 50:50 with water, capillary action wasn't really to be seen, left it to dry then tried to clean up (dry time was only a few minutes) used a qtip to clean off and found i had to apply a lot of pressure (and moisture) to lift the excess, in doing so removed most of the paint in the lines.
2, Applied the wash heavily (not diluted) across the whole tail plane, really worked it into the lines, left again for a few minutes and then tried to clean off, the wash was literally welded to the surface, and took a lot of hard scrubbing to remove the excess, again in the process took off most of that in the lines.
3, Third attempt was back to the careful method, and i mean really careful trying not to go outside of the lines as much, tried to clean up along the way, but again ended up taking most of the wash out when cleaning up.
So i kinda got a bit stumped now, most of the articles/videos I've seen are pointing towards using light pressure and a hardly dampened qtip/kitchen roll but at no point in my above experiments was i able to remove anything with 'light' pressure or a hardly dampened qtip (i often found i was soaking it in order to remove the excess)
Any suggestions on the above? Am i going about it in the wrong way?
Another quick query i have is should i be looking to fill 'every' panel line no matter how large or small, as there are a few rounded hatches and other less defined lines, or should i only be looking at the major ones, flaps and so on?
Many thanks in advance.
Matt
Matt
