Panther G MAN Charlottenburg scrapyard 1945
Hi Keith the foam is Xps Styrofoam and the surface is very fragile you can water down PVA glue and paint over the foam this will harden the surface ready for paint but I just prime the foam with tamiya acrylic black then I spray two very light coats of a automotive plastic primer let this dry then apply your base colour.
Hope this helps
Dan B
Made some more progress on the base cobblestones painted washed and grouted ready for the final dusting and earth effects i also scratched some bits a pallet with some scrap ready for salvage more bits will be added then i moved onto building some building aids such as Acro props and a stand as this model is around summertime 45 i wanted to add some bits that could of been used in the clean up and restoration of Berlin the Acros need some detailing before painting can start.
hope you like it :-\
Dan B
The 'grout' is acrylic medium , PVA ? ???
Placed so not to occlude the surface texture ?
Sorry for not replying sooner to your questions the grout i used is the same you would use for floor tiling just i add some PVA glue to make it more workable hope this helps you all
As always thanks for your comments
Dan B
I have added and painted few details not far from the finish line now ;)
Dan B
Stunning details...camo pattern looks excellent as well as the weathering!!!! Diorama looks amazing too!!! I really like how you did the base with the camo pattern. That is just wicked.
Thanks Tanker i appreciate your comment :)
Dan B
Thanks BJ glad ya had a look in fella thanks for the comment
Dan B
The scrapyard Panther dio is now finished i took this model along to a show this weekend and scored a silver award in the comp i was truly gobsmacked by this it also recieved some good attention through the day thankyou to all who have commented on this build much appreciated heres a few piccys of the finished piece
Dan B
