I had the same thought as Momo-what kind of glue did you mean, glue for styrene, CA glue, etc?
I use glues made for styrene with styrene, and not CA or 2-part epoxies, because I want the weld bond that such glues provide. I always used Testor's tube glue, both when I was a kid, and when I got back into building models (geez, that's now about 25 years ago!).
When I got back into the hobby, I learned about liquid styrene cements and starting using them, too. Like BTrekker, I first used Plastruct's products-Bondene and Weldene-to get used to working with liquid cements.
Like Momo noted, you get capillary action with liquid cements, and for me, building airplanes, I find that works very well, flowing the cement into seams between fuselage halves, or wing tops and bottoms. And it makes it easy to use the "beading" technique, to help reduce visible seams. As the glue flows into the seam, you apply a little pressure, till a bead of melted plastic is extruded along the seam. When that cures, you can scrape it away and reduce the amount of filling and sanding.
From Plastruct's liquid cements, I moved to using Testor's liquid cement in the little black bottle shaped like a quarter wedge, with the long applicator tip. And then I started using Tamiya's Extra Thin. I still use Testor's tube glue, too, for pieces where I want a little time to make adjustments.
I use CA glue and 2-part epoxies for bonding unlike materials, like metal or resin to styrene, or resin to resin or metal, and metal to metal.
