Belugawrx
- Jul 22, 2013
Just saying, I've had some bad reactions with it on Testors enamels...try itThat's not possible. Tamiya panel line paint IS enamel.
I have Tamiya Paneliner too -in black and brown. In my experience, I've had zero issues using it on enamels, lacquers and acrylics. Maybe yours reacted badly on Dupilcolor paint.Just saying, I've had some bad reactions with it on Testors enamels...try it
I got to thinking about your comment. I do have one question though…. did you spray a coat of clear prior to using paneliner or did you apply the paneliner before spraying a coat of clear?I've used Duplicolor primers and paints for years, never a problem..be careful with the Tamiya panel accent, it does not like enamels!!
Yes. The paint has to be glossy when you use panel line paint otherwise the surrounding paint will "absorb" it.I got to thinking about your comment. I do have one question though…. did you spray a coat of clear prior to using paneliner or did you apply the paneliner before spraying a coat of clear?
I'm suspecting you didn't spray a clearcoat prior to using paneliner.
I plan to use the wide stripe decals included (white or black, can't decide). How about after that? Assuming I don't &*%$ the decals first.Not a fan using Future as a clearcoat. You've got a nice finish now. Why ruin it with brushing Future. As long as you've got a nice glossy finish, you don't need a gloss clearcoat.
Please do not use either of those on a scale model.
Because it's a clear acrylic liquid, it's cheaper than gloss coat products from the model supply companies, and because they get results with it that please them.I can't understand why people put Pledge on their models. Pledge is for floors....
Believe me when I tell you this, it does wonders fixing cloudy windshields and aircraft canopies if a builder used CA or superglue on them CA/superglue fogs clear parts. Would I use it to as a gloss coat? No. As one already mentioned… it turns yellow over time.Please do not use either of those on a scale model.
As I mentioned before… I've been building model kits for 50 years. I've used hardware store rattlecans and Testors rattlecans - both colors and clearcoats over the years. I've figured out what works and what doesn't work for me over the years. Yes, hardware store rattlecan paints can be used on plastic. Heck, I've used them on my car models in the 70s. I still use it now; nowadays preferably Rustoleum 2x colors and clears (gloss, flat and satin). Very rare I have issues with them. You just got to know how to tame them to get that nice coat. Don't spray too close, spray in several light coats from at least 12 inches or more away, but never go slow on your passes. Definitely don't spray in cold, windy weather or very humid weather conditions. It's all about experimenting and learning.And that Rust O Leum. That stuff is for larger project. That spray can sprays put like a fire hose. Yes, you might have some success with it, but it is not made for scale models.
If you do not have an airbrush I suggest Mr Super Clear spray cans. That stuff is amazing. It is so good, I have an airbrush and I still use it sometimes because then I don't have to clean out my airbrush. And the results are amazing. Tamiya gloss clear is a very close second. Also a great spray clear.
Krylon isn't what it used to be and that's why I won't use Krylon period.
Rustoleum 2x primers sprays really nice. I often use it because it's economical to use. I only use two primer colors - white and grey.
And yes, I do have an airbrush - 3 of them in fact.
In closing, stop telling folks that Rustoleum paints are not made for plastic! Yes, they are! I irritates me to no end hearing/reading these paint "experts or snobs" making statements that they're not. I think it's a matter of choice of the builder to choose.
I've never used either so I can't comment on them. I'm sure they're both good products. As of late, I use Testors Gloss and Flat clearcoats on all my aircraft model kits via airbrush and am happy with them.
