Splashcoat
- Oct 9, 2010
@ Unreality - Maybe that's why I'm getting inconsistent results with hairspray, I've been experimenting with how much to use and I tend to use a light hand when airbrushing. I'll try applying a heavier coat and see how that works out. Thanks for the advice. I WILL be adding a gun turret; I'm using the Hayne's shop manual as a reference for this build and it indicats that a "stock" YT-1300 has a double barreled top turret as standard equipment. My plan is to replace the dorsal quad turret with a dual and fill in the mounting points for the ventral turret.
@ Stretch - Wow! That is a great idea! The parts fit in that area is pretty sloppy and there's a lot of missing detail on the inner surfaces of the manidbles. A cargo pod would cover all that up very nicely and give a pretty unique look to the model. Thanks for the input!
