USN F14-A 1/72 from Academy
That Tomcat kit had three sprues, I've never built a 1/72 aircraft before but that is high. I've built 1/48 Tamiya planes that had 2 sprues. So it seems to be quite complex for a little guy.
Keep in mind how big an F-14 is, though. It's only about 3.5 metres shorter than a B-17 (so ca. 5 cm in scale) and has two-thirds the wingspan with its wings forward, or with them folded back, its wingspan is somewhere around the span of the tail on the B-17.
FS colors are a good place to start, but I think the reality is most paint manufacturers do not "scale" the colors so they wind up being darker than on the real thing. Also, weather, sunlight and other factors alter the way colors look.
i.e. in the end, a prefect matched FS color may not actually feel like the right choice anyway
For example, I swear most Ghost Greys I see fell too blue and dark. I have even gone to the naval air base museum near me and tried to match colors to the planes, and just about everyone look too dark or saturated, even when those are considered the "best" or "closest" matches to actual FS color swatches or sample panels
for example, Vallejo Dark Ghost Grey compared to what would be an FS 36320 area on this A-10
and then you get all this stuff for paint colors that are all supposed to represent Dark Ghost Grey
Funny thing is, many of these could look like closer matches depending on lighting, weathering, and other factors
For example, same plane, but a little farther away and on the shaded side it looks darker/bluer and actually matches the Vallejo color better
Same with Light Gull Grey FS 36440
Even though this is a fairly close match, I just feel like the things I have painted this color are way too dark compared to how the aircraft look sitting there at the museum or in pictures. And this I attribute to the scale factor and the need to lighten up colors the smaller you get model wise
Yup yup and yup. That's why your room never looks like the house paint colour on the swatch. The smaller the swatch, the darker it looks.
If you can, a small can of house paint rolled onto a m² of wall will save you a lot of grief if 'that person' (they know who they are), insists on a perfect match with the couch!
A dumb question... it's allways necessary scribing the panel lines of a model kit? How to know when to do it and when it's OK not to? And the best moment for scribing is before the primer, or after the base coat or at the end of the painting process just before panel lineing itself?
Thax.
Thax.
Most kits these days have recessed panel lines. The only time you need to rescribe them is when they've been removed by sanding, usually along joints.
If the recessed panel lines are inaccurate or missing, fill the incorrect lines and scribe the correct ones.
With older kits having raised panel lines, you can sand the raised lines off and replace them by scribing.
The best scriber I have ever used is sold by UMM
Thax.
A good number of kits (at least aircraft kits) have way overdone panel lines that if scaled up would be like huge gaps/
I feel like if a kit needs panel lines, or has raised panel lines that you want to convert, it is better and easier/more forgiving to get a really fine mechanical pencil or similar to draw them on instead of scribing. Except for maybe certain areas that represent parts not actually joined or certain removable hatches etc...
also note, in some cases, raised panel lines are actually accurate
Thax.
First off, I'm very familiar with model contests. The main thing is to have fun building your model and learn techniques from more experienced modelers. Will be very helpful if the judges leave comments on your entry sheet if improvements are needed. What one judge sees as an issue another may not. I have had models not place at all in one show but then place 1st place in another show a short time later. One of these models was a German armored vehicle which I was certain to win at least a 2nd place but didn't get zip. About two months later I entered it in another show and won 1st place gold. I later found out that the reason my model didn't win the first time was because the individual judging that table didn't like weathered entries regardless how realistic the weathering was.
As for your color question, there is no magic formula for the "correct" shade. Manufacturers have slight differences with shades as it happens in real life with the real aircraft. Too many variables involving lighting, application method, coverage, weathering etc. will display different shades of the same paint. Best you can do is to approximate the color.
And yes panel lines are WAY overdone on models and most are overdone. Next time you are close to an aircraft check out the panel lines and you will see how thin and shallow most are. Dirt, oil and gunk gets trapped in these lines and sometimes makes them pop more than what they really are.
0 Words
