dkev I use the Patriot 105 as well but it has me severely curious to ask you a few questions in regards to your patriot. I dont know if I have a defect in mine or what but anytime I paint a kit it appears that Im using twice the amount of paint I should be till its all said and finished. Im in the finishing stages of the Nascar kit Im currently building. From start to finish, I used 3/4 of a 1/2 oz bottle of both Gloss and Flat Black (All parts BUT the Nose, Hood and Body), and 1 1/2 oz of Flat Yellow all bottles Model Masters Enamel thinned 2:1 with cheap cold lacquer thinner, spraying at 20 PSI.
Is this the normal amount I should be using or am I using way too much paint and if using too much why is this happening ? Is there a defect with my airbrush, am I spraying with too much pressure, is my fan in my spray booth producing too many cfm's and sucking paint before it hits the part ??? Another question I have does your trigger stick ? Alot of times when Im spraying when I leave off the trigger it doesnt pull all the way forward or continues allowing air out after I leave off the trigger. Question 3 I noticed just the other day while cleaning the airbrush, when I clean the airbrush between colors. When I put Alcohol, lacquer thinner or windex in it to clean it, then spray it out I notice that it doesnt shoot out at the pressure it is set at. Like the first burst is proper with the right amount but after about a second or two of it spraying out it sprays out as if its very minimal pressure. If you or Anyone can give me some advice or answers I would greatly appreciate the help.
