DreamKnight
- Dec 8, 2009
Ok you're building your tanka nd you run across some pretty neat information about it or the history of it. You remember any moments you thought was cool to share?
Chiefpettyofficer said:I HATE those Vinyl-Tracks!!!!
panzerace007 said:While I may talk about th German Army & th Waffen SS I want to make it perfectly clear that I DO NOT believe in there politics & are drawn to them as a War Machine they were a tough nut to crack.
ERIK
HWR MKII said:The rubber on the tracks isnt for ride comfort. Its to protect the roads. Bare metal tracks will tear the crap out of asphalt or concrete. The rubber cushions the track to road contact while still supplying a good grip on the road that the cleats on a metal track would have had. They are also cheaper to manufacture than a solid metal track. There is also a mild weight savings. If the roads are icy some tanks can have track pads removed and replaced with a cleat. These cleats are very obvious on modern german vehicles.
Right now the only way you can legally drive a steel tracked armored vehicle on the road is if there is NO other type of track for it. Bren carriers and german WW2 tanks have this problem. Most times though any surviving german vehicles arent driven to shows they are trailered and then driven around the show ground. A 250/251 series halftrack is perfectly street legal as it is.
HWR MKII said:Right now the only way you can legally drive a steel tracked armored vehicle on the road is if there is NO other type of track for it. Bren carriers and german WW2 tanks have this problem. Most times though any surviving german vehicles arent driven to shows they are trailered and then driven around the show ground. A 250/251 series halftrack is perfectly street legal as it is.
panzerace007 said:Aside from the Petro issues, It would still be cool to be able to drive a 251 around ! Although th front wheels are not powered.
As far as having a Military Vehicle that's really street legal. I like that Heavy Duty "Jeep" . I think it's called a Unimog ? I thought They had an SUV version ...
