1/144th Prometheus scratch build
Evenin All,
Thanks for stopping by, nice to have you all along for the ride
Finally got to the bench this weekend,
JohnSimmons said:
Very clever mate ;)
Oh and I've been watching Bottom lately while I build....
I've been watching this guy
http://www.youtube.com/channel/UCcBnT6LsxANZjUWqpjR8Jpw
Very Cool
But on with the latest........stuff
Lots to show you so lets get going,
Sanded the primer and re-filled the problem areas
Moved on to the head assembly,
Neck spacer
Slotted the head and neck to get the correct dimensions
Shaping the nose
Made some spacers for the top section for later
Marked
Cut
Drilled and finished the edges
Threaded tubes through the holes
Taped in position on the underside
Beauty shots
That's it so far
Take care
Gag
Ello Every Peeps,
Thank you for stopping by chaps,
Once again lots to show so lets get too it...........
Marked out, cut and finished another underside assembly
Added some tubing for rigidity
Drilled wiring holes in all the brace pieces
Re-assembled everything, this time gluing as i went
Taped in position
Started on the rear underside body
And in position
Then back to the main section
Some supports
Glued to a sheet of 1mm styrene sheet
Then wrapped around the spacers to achieve the correct shape
Then both sides are trimmed
Then more underside supports are added and the edge is finished to this support
Added a hole for the stand
Then some supports for the tapered transition piece
Then on to the front section
Added a spacer cover because it wasn't pretty but i can hide it later whats important is the basic shape
And thats about it for now
Still more to come
So stay tuned
Gagster out
Eh up buddy,lovin the progress.. it's really takin shape now,this builds gonna
be epic.....top marks me old cock sparra! ;D
have you counted up the number of lights in this monster?
cheers peza
Evening Experts,
I have a very serious question for the brother/sisterhood of all things nerd/geek/fanboy/artist/creator/modeller/prop builder.....thatever.
Today, I watched the movie, .......well, the part's with the ship in it to be honest, because lets be honest,
Prometheus the movie- 0 - Visual Perfection 1
After watching said movie, i did in fact notice, that, the number of flashing or strobing lights on the engines was zero
Now the other last week i had a 50 minute conversation with Mr VooDoo himself, Randy, Thanks mate for bieng so honest
and well, just so cool to chat with. You gave me some ideas and i thought i had discovered my solution, four light units, one per engine with strobes, constants and flashers in a small curcuit board for under $60.
But then I watch the film.
I said that this build was more water pistol than cannon, but i think my lights could be better than the original. Strobe, flashers, markers and enough left over for the power unit.
But the down side is the cost, 5 x $60 is a lot of lolly.
I think reality/cannon i could get away with one, may be two.
Just interested to know what you think?
Gag
Eh up buddy,is it possible to have it landed and then there's no dear engine lights?
still have all the bling of the other lights though! peza ???
More genius stuff going on here mate! Carry on the good work it's really taking shape now.
Thanks for the input chaps
I have just found out that some of my pictures have been deleted, this is obviously, very annoying, but not life threatening so, i'll continue on with what we got,
Did this part twice because it was a bit big when done in plastic and not looking so good when dry fit with everything else so I ripped it to bits and started again with foam.
This really is trial and error modelling at its best folks
Sanded it into shape
You can see the nose has changed a bit as well, I put a piece of 1mm to flatten out the top then filled and sanded it to shape, it's now ready for its final coat of epoxy and a good finish sand.
Added another strip of 1mm to give a positive front edge, needs to be filled and sanded next.
Some fat bloke in a mask to give it some scale, she's a big bugger she be
And finally a small video 360
[youtube]https://www.youtube.com/watch?v=Ype2b-MoDm4&list=UUHiAjjyN8V35Dg2k-4Fcx1Q&index=1[/youtube]
And thassit for now
Stay tuned
Take care and stay warm friends
Gag
(PS got really chilly here in Miami yesterday, into the low 60's it was :cool:
Eh up gagster,sweet update bro!keep them coming,can't wait to start seeing some meat on these bones...
Top job so far,but there's never no doubt with your builds....peza
