1/144th Prometheus scratch build
Excellent work here, as always. I love the warm yellow glow of the zillion watt LED's for the engines! :D
Quick question: how do you cut your circles out of styrene sheet? Cool tool or technique, or just "very carefully"? ;)
Evenin all,
Thanks guys much appreciated.
The full array,
The one i use depends on the accuracy required and the surface/material to be cut.
Lots and lots to get too, soooooooooooooooooooooooo......................... everybody ready
Standby
GO
Started work on the engine internals, basically a hinge mechanism to achieve the slight "in toe" it adopts when landed because i do plan to have both, "in flight" and "landed" options.
first i oval'd out the inner wall opening
Fiddled until i got the angle looking right and attached the location sleeve
Made top and bottom rings and spacers
X four
Two left, two right.
Dry fit
Straight
Angled
Prep the bottom of the outer ring
Outer support wall gluing
X four
With shafts
Complete assembly
Bulb holder and support ring
Rotating hinge
Inner wall
Outer wall
Dry fit with dome master as stand in
Engine pivot assembly
In position in the arm
The story so far
And thats it
Forgot to wish my Prometheus Happy birthday
Started on November 1st 2014
Have an all day session planned for saturday, my wife is busy all day.
hope to have all engines attached by next time
Thanks again for the support
Take care everyone
Gag
Simply stunning!!
Huge progress there chap!!
I was wondering what you may be considering after this epic build?
May I suggest Serenity?
You skills would be perfect for such a boat.
Excellent update Sir Gag...
Good to see you back at it ...
Hope all's well with you and yours
Cheers
Evening All,
Thanks for the kind words guys.
Hit 335 hours of work so far on this bad boy, really beginning to need details.
Ive decided that as this is only a water pistol Prometheus and not 100% cannon that i will be using artistic licence with some areas of the ships details and it's lighting effects.
You have been warned
Enough chit chat
Slush casting first attempt,
took the mold and sandwiched it between two boards with all thread on opposite outside corners.
Pour hole.
Weigh and mix my Smooth-on 300 and pour into the cavity
Spin by hand being mind full to coat all the right areas
Warning action shot
Keep it going
At least five minutes if you wait until the plastic/cup starts to warm up in your hand whilst you stir it, its all about timing.
Warning another action shot
Leave for ten mins and then pop them out. It's a good upper body workout i tell ya. Hollow domes, need a bit of filling here and there but its a good base to start from.
Together with nozzel
Moved on to the engine attacher thing
Made four
Cable access
Dry fit
Money shots
Started on the joint surround. took a while, one bondo disaster in the middle. epoxie problems. basically it was a complete pain in the buttarks
So here is a selection of pictures that require no words
Needs only a final sand
Started on some of inner engine details, hoping to be casting these as small assemblies soon
And thats about the size of it so far
Enjoy Episode 7 everyone
I'm doing a marathon of the Bluerays, the wifes away all weekend in New York, then i'll go see it in the middle of the night when it might be a bit quiter
Anyhoo
Take care my friends
Gag
OUT
Wow gagstar she's movin on mym8! How's the hand with all the shakey shape in ya action shots bro?
Top work as always :eek:. Peza
Ello,
Not been about muchly
Been off the boil a bit,
Dry spell,
Just got into it again
Thanks for stopping by, very encoraging to know you guys are with me
Finally managed to get this bloody thing finished and molded
Also molded the top cap
Bashed out four of each
Then it was on to the best bit..................................................freesyle detailing.
Marked my canvas and began cutting relief so the tubes could be angled correctly
Then we were off and running
Used items i had four of in my scrap bins, i put three aside for the other engines
Started on the outer cylinder assembly
Like everything popped out four
Tom's set, Dick's set and Harry's set.
Main tube
Ready to mold
Beginning to fit all the castings together with the detail assembly
Dry fit
And thats all she wrote
Cheers
Stay frosty
Gag
Nice to see the behind the scenes effort behind the progress. This is looking awesome. I get a kick out of the names for the pile of parts for each assembly. ;D
Good to see you're making headway on it. Quite a massive project, and I can only imagine how much patience it would take to get the bulk forming work done while you want to just add details and do the fun parts.
Good to see you back at it Gag :)
Hope your '16 is better than your '15 ;D
See ya round
Cheers
