1/48 Hobbygawa Fw293A-2 / U1
Presenting the Mirror Master 1000 .
Wherever one pointer is , the other is always in the exact reciprocal position from centerline .
This will make it easy to build to 1/10th mm tolerance , which translates to 1/2 cm tolerance in 1: 1 -- ugly , but ..
Stepless dimming LEDs .
+ / - 5 mm fine tune height adjustment .
No build pics , any questions just ask .
View attachment 140628View attachment 140629View attachment 140630View attachment 140631View attachment 140632View attachment 140633View attachment 140634View attachment 140635View attachment 140636View attachment 140637
Cool. PM
That white paint band was for a position indicator scale , but the pincer tips sit at 8 times that gear radius away , making the gear teeth barely move in relation to the tips , so the scale divisions would need to be too tiny to be practical .
Could still be useful with different pincers installed in the future .
The below arrangement reduces that 8.09 : 1 ratio down to 1.1 : 1 .
1.1 since it's restricted to material on hand - mainly the 3" radius of that old protractor .
It's just to provide a visual indicator for the tip positions for repeatability when needed so the actual values are irrelevant - plus , the protractor is marked out in degrees and not millimeters for some reason . Ridiculous .
It still barely moves since it is tracking only half the division . Moving the tips 1 cm apart moves the pointer 4.5 mm .
a 1 mm spread moves the needle only .45 mm -- 90% of half the total gap at the tips .
Good enough for now . I don't think it will even be needed on this build .
Been a minute......or two since I've been on here but I am glad I peeped into this thread to see what's been going on. Jeez.........this is completely mind blowing stuff going on so far. WOW!!
You definitely have my attention bud.
