Re: 1/72 Airfix Avro Vulcan
I haven't been able to work on the plane as much as I'd like, but still managed to squeeze in a few hours here and there. Most work has been cleaning up seams, sanding, putty, scribing, you know, the usual. ;D
Last night the cockpit canopy went on and a last coating of white paint was applied to the inside of the air intakes. Bomb-bay doors were glued on, as were the scoops on the belly side. I wont even post pictures of it since it looks like a murder scene... Maybe after paint :
At this point I couldn't take another round of putty and sanding, so I believe she's ready for primer. The air intakes were a PITA to mask. Masking tape I found impossible to work with in the tiny space, so I went with bluetack (which isn't even blue)
;D .
And finally, PRIMER!! As you will notice, the the putty seams are still somewhat visible under the paint. But I'm very happy with how it turned out, so I probably wont go in to fix any of them. However most importantly the scribed panel lines came out better than I ever thought they would!
