Airfix 1/24 typhoon rebuild for a friend
Ooop !
I was looking for 1/24 .
It's all mixed up on that page .
Plenty of 1/72 too .
You'll need to go find one at a museum or something and map out the canopy , sculpt out a casting buck of it and vacuum form a new one .
Use minimal water in the mix to minimize shrinkage of the plaster .
Probably best to use something like Densite as it cures much harder than regular gypsum plaster .
The part's have arrived so finally got the flaps sorted out.
I think the guns next possibly.
Pantherman
So all the flaps sorted. Guns next. I removed the two gun supports and have made up 4 new longer one's with a metal gun barrel to be fitted. Think it will look better when sprayed up.
Have decided to leave the engine as it was pretty much ok. I will clean it a bit, prime it and eventually hand paint the engine and pipes. Pantherman
Guns done. Trying to tidy up the exhaust, think im going to remove the existing as some of them fell out during the cleaning and I put them in the melting pot so gone forever !!
Think I will glue the exhaust covers and leave the top engine cover loose so I can play with the engine a little. Pantherman
View attachment 109261View attachment 109262View attachment 109263View attachment 109264
Got the engine done. I used blutac to temporarily stick the engine cowling down ready for some top coat.
Had a go at improving the landing gear wells while I was at it.
Ready for the start of the top coats now I think. I'm leaving the undercarriage until later on so nothing gets broken.
20231125_140820.jpg20231125_144701.jpg20231125_145150.jpg20231125_150946.jpg20231125_150958.jpg
Thanks. There was just way too much paint on it previously which obscured the great details.
I'm doing the underside top coat and stripes today. Pantherman
So the underside is painted and the stripes are done. Have to say I'm really pleased with how it turned out.
Forgive the Ps, couldn't help myself. 20231126_155527.jpg20231126_160353.jpg20231126_160403.jpg20231126_160411.jpg
Need a little help now from you all. I want to really show the rivet details but not too sure how to go about it. Thought I would gloss coat the paintwork then try a watery black wash over the lot, then rub off the access with a foam cloth. What do you think??
Pantherman
Forgive the Ps, couldn't help myself. View attachment 109434View attachment 109435View attachment 109436View attachment 109437
Pantherman
Managed to get the beast masked up again and sprayed the top coats on the upper wing's and fuselage. Bonus. Pantherman 20231126_174353.jpg20231126_174402.jpg20231126_174410.jpg
Base coat of gray/green done so just the top coat of thinned olive green to finish it off. Pantherman View attachment 109707View attachment 109708View attachment 109709
Little bit more done. Camo finished apart from a few minor touch in's. Front of the engine done although I hate doing white. Prop almost done, just got the tips to paint. Pilot is getting acquainted with his upgrade !!!!
Think I just need to touch in some of the cockpit as I haven't done anything in there yet. Pantherman
20231202_180930.jpg20231202_180937.jpg20231202_181000.jpg20231202_181008.jpg20231202_181013.jpg20231202_181017.jpg20231202_181029.jpg20231202_181125.jpg
