This plane has a lot of issues, the nose is not circular, rather cut in half and molded together, lots of gaps eventhough I already puttied most of the gaps, intake one slightly large and the other one small so need to add more putty. since this is my first plane, I learn a Lot... first is to read reviews about a kit that you will be building, then planning then scribbling if you got a raise panel.
Sweet! I've always been a fan of the look of this jet, it looks very bird-like and has such graceful looking lines to it. Looks like a fun kit. What colors go on the trainer?
Hi Cave, I'm planning to paint it black with a white wing tip. still need a lot of sanding and puttying before painting the base coat, thanks for the comment!!
