Aliens Class II Power Loader
Main cage hinge section is almost complete.
Added a bit of interest in the area that gets revealed when the cage is up.
Then it was fork time. Sawed them off then started to fill in the gaps.
Your really giving this old kit the 9's. Can't wait to see more.
-Ozz
Slow going on this...
Suggestions for cutting out this center slot? The one I did on the left is twice the size that I need.
Everything is looking great! That's a metric crap ton of work to slice and dice this kit. It has virtually no joint mobility OOB. Keep it up!
For your slots, you could drill them out. Drill a hole at one end, move the part slightly left or right (depending on what end you start the hole, then drill another hole. Repeat until you reach the other end of the slot. Just be sure to drill holes slightly smaller than the desired slot width. After the holes are drilled, clean up the slot with a flat file.
Do you have a drill press? That would make the job a little easier.
This is a very very cool build sir..Luv the work so far and looks like you needed the full size one to deal with that workload.LOL.. Can't wait for the rest.. :)
Thanks for the suggestions CheesyGrin, appreciated. Wish I had a mini drill press!
Just discovered this thread Ian. Awesome subject and I can see you are going all out with the details. Very Cool!
dude,dude. i live the original alien movies from when i was little. this awesome modification is so awesome. i need to take notes from you. :eek: ;D ;D ;D DeadRs
