Aztec Warrior 1950 Ford Lowrider Custom (Updated 9/1/2014)
Re: Aztec Warrior 1950 Ford Lowrider Custom (Updated 7/1/2014)
thanks guys, yes i can smell the fumes already, the next updates will finally have color in them, i am in the process of final body work getting it ready for the paint booth!!! Now I can see the light at the end of the tunnel, all that is left is paint, engine and final hyrdo hook ups so the end if very near!!!
actually got the silver base coat on this afternoon and the body work looks good so a few days to dry and here comes the color...... yeah very pleased I do not have to go back to body work , whew....
Re: Aztec Warrior 1950 Ford Lowrider Custom (Updated 7/7/2014)
Little update, all the parts got the color coat today now its wait a few days and then clear coat then the clear coat sanding stages, I never thought I would make it this far Yeahhhhh!!!
another little update, finally figured out what to use for the aquarium water, totally dry and has enough bubbles in it to be convincing, only problem is no fish, that is my next task in the future to figure out what will work for fish!!!
A little sneak peak of the paint color, this is the hood with a graphic that I cut out of a lowrider magazine that I glued to the hood and will smooth out with clear coat to act as a mural. It matches the rootbeer rather well..
Re: Aztec Warrior 1950 Ford Lowrider Custom (Updated 7/28/2014)
Rockin' update! Love that mural!
Thanks guys for the comments. While the paint is drying between coats doing some detail work on smaller stuff, the engine is painted and that I colored gold. Give it some contrast, but here is the overflow tank that I made and radiator cap, just have to glue other end of hose to cap.
the engine color, i was going to paint the truck this color but on a sample shoot i was not to happy with it but figured i would change it up a bit give some contrast under the hood.
a better pic of the hood mural and a decal that I had from a revell semi I decided to add to the bottom of the cabs floor board that could be seen underneath the truck.
More updates, decided on a little pin striping here and there on the body, and working on the clay pots for the beds and trailer, some are done with some vegetation and rocks ill add some fruit to others, and the hood ornament.
Mrcivicwithstyle, thank you for the comment....
The bed of the trailer, the bed of the truck will be the same with the taillights and pyramids on the tailgate.
engine drive shaft and the contrast with the root beer of the frame.
a little something I will be adding to front of the trailer....
Engine is almost done, just need to route the spark plug wires alternator wires and and some fuel lines....
added skull to hitch post....
Wicked!!!
just a little update, fitting engine in bay with hydro tubes, was not easy had to remove some of the drivers side resin face, I did not mock it up very good during primer stage, but little adjustments never hurt anybody....
Decided to paint the vine to look more realistic.
Did not like the way the paint came out on the bottom of the bed, decided to use toothpics to fill it in the frame which will cover most of bed when installed.
