Down Time
- Dec 17, 2022
I have to build a test piece, bitting my nails......Looking really good DT. I am anxiously awaiting the water effect.
You will do fine. It's a relatively simple process. Just make sure any seams or edge barriers (I use acetate sheets) are sealed with clear silicone (or clear epoxy)I have to build a test piece, bitting my nails......![]()
I'm almost there......You will do fine. It's a relatively simple process. Just make sure any seams or edge barriers (I use acetate sheets) are sealed with clear silicone (or clear epoxy)
Example:
In the picture he uses foam and epoxy. as an edge barrier. I prefer acetate sheets (which i glue on with Elmers white or Aileen's glue) and silicone as it will peel off easier that the epoxy.
This is looking really nice. Great work.
Thank you!!This is looking really nice. Great work.
Loving the colours, great details. Pantherman
Thank you, Kind Sir!Loving the colours, great details. Pantherman
Looks coolPending approval by my friend, the remains of a sea serpent on the sea floor.
The buildings are old kits my friend slapped together, misaligned too much glue..... I had to take them apart re true the edges and reassemble them, scroll back and you'll see.Looks awesome. Truly does.What material did you use to make the buildings?
Nice
