You can use modge podge or other acrylic medium to get texture on the "water".
First time working with the stuff, maybe I'll add a surface texture.It took me a moment to spot the resin at all Are you going to tint it to give the impression of muddy water a little, or keep it completely clear?
Ocean front, I'll try a little wave actionI'd at least try adding some translucent paint to the surface, else the water will look so clear nobody will believe it's supposed to represent a river
Good advice, but if the water will have visibility from the side (as I see many displays have) the opaque grime will have to be added to the resin.I'd at least try adding some translucent paint to the surface, else the water will look so clear nobody will believe it's supposed to represent a river
Sides are boarded upGood advice, but if the water will have visibility from the side (as I see many displays have) the opaque grime will have to be added to the resin.
I'll play.....In that case I would really add either wave texture or colour to the surface (or both), because otherwise, the resin will be hard to see. If it would have "open" sides it would be more obvious, but with the sides enclosed many viewers might not realise there's water there at all.
I'm going to try a wash, greenish gray in a spot under the docks, see how that looksWell-poured, no bubbles etc. that I can see, but I do feel the photos illustrate my point quite well: if it wasn't for the glare from the overhead light and the line where the "water" hits the shore, you can hardly see it's there at all.
