Chris S
- Feb 14, 2011
I shall try again !!...just got this all done and had a crash
Oh well here we go again !
Now the face is dry ,we can move onto the'Wet on dry ' stage
, you can see the difference in the colours now too .
The next step is to add the final highlights (if needed ) As I mentioned at the start ,this fella is going to be pale skinned ,with a bit of red and blue about the face , Like myself he would be naturally a purplish Blue /White colour as we dont have the dark skin pigment that some one from ...say South Africa would
So first up ,I put on the White highlights ,you can see where these need to go in the pic below ...
This is blended in the same way as 'wet on wet ', by stippling the paint with a dry brush until the edges are feathered in . As I want a tired and battle weary look to the face ,I mixed up some Prussian Blue and Crimson ,This I added around the bottom of the eyes .Using a fine brush and wiping most of the paint off ,I carefully pull the brush down from the inside corner of the eye and along the bottom of the bag below the eye,Then work this in a bit with a clean brush . At the same time I've also put more Crimson on the upper cheek ,This is the start of the cold look .
Now with the cheeks all blended ,I added some tiny flecks of Prussian Blue around the cheeks ,Once stippled or blended with the Crimson this will make the cheeks look cold .
The last thing I've done for this stage was to add a wash of Raw umber to the hair,This will create my shadows ,and also show up the colours on the face better
,The hair is still wet in the following pics thats why it appears shiney
And I've put this next pic in just to show the difference from the start of this stage .....
So ...we're nearly done with the face now ,when its dry I'll sort out the eyebrows and re check for any flaws,Following that I will move onto the hair ;D
Thanks for looking ...Questions & comments most welcome.
