CheesyGrin
- Sep 1, 2012
Good to know Grendels! I've seen folks use 5 minute epoxy to attach fiber to the LED, too. I tried exoxy on a Cyclon Raider build and it worked OK - until the plastic fibers broke off. :'( I guess there was too much stress on the fiber from the bending around.I usually use brass for my fiber bundles, but never like that... You can center them almost as well with tape.
Thanks fblanton! Glad to share. Lighting is a great challenge and, when executed successfully, adds much to the final build (IMHO).Great build log on lighting your model CheesyGrin. Thanks for sharing all the diagrams and how to images. I have not tried this yet but after being in the hobby for a number of years I do want to give it a try.
Adam Wilder is an AFV (armored fighting vehicle) modeller. He's known for his hyper-realistic painting and weathering techniques. Here's a link to one of his builds:
http://www.network54.com/Forum/110741/message/1351418460/LVT+Saipan+1944
Got some bench time today and made progress on the lighting. The focus today was the thruster LEDs and reflectors. I also routed the power wiring in the base. Here are the pics:
I fished a single wire through the base. Next, I soldered the wire to the two wires coming from the sub-mini jack. This allowed me to pull the wires through the base:
I needed to make the reflectors, well, reflective.
This is the metalized parts painted but prior to buffing:
The reflector on the right is after buffing with a Q-Tip:
I wanted the thruster color to be amber. So, I mixed some Tamiya Clear Red and Clear Yellow and sprayed the thruster LEDs:
Heres the completed thruster assembly. The back is painted Nato Black, just to ensure no light bleeds through:
And, finally, the amber thruster all lit:
All that's left is to install everything in the model. Then, actual building and finishing can begin! ;D
