Thanks for the advice, much appreciatedi would cut the bottoms of the cannon pieces off flat and super glue them, once you put the halves together your kind of screwed if they come lose.
I would take one of the cannons and mold it then make new ones with resin. But that's just me.Got a little bit done. There should be 56 cannons but 5 are missing. Loads of flash but it's a very old kit. The cannons are very time consuming and that's without paint. Pantherman
View attachment 124802View attachment 124803View attachment 124804View attachment 124805View attachment 124806
Mine has seperate hatch doors and i considered that, but i felt that was too easy lol broomsticksYou could possibly just "close the hatch" on the missing ones below deck. Not sure if the kit has separately molded hatches or not
Of course you could take a page from the Doolittle raid and replace the missing guns with broomsticks
Not quite broomsticks but sprue and german infantry ammo pack's should do the trick. I will post some photos when I get round to making them. PanthermanYou could possibly just "close the hatch" on the missing ones below deck. Not sure if the kit has separately molded hatches or not
Not too happy with the stripes, only myself to blame as I used a cheap masking tape that was the right size. It's gone in the bin with the other 4 reels of varying sizes.Got a little bit done. There should be 56 cannons but 5 are missing. Loads of flash but it's a very old kit. The cannons are very time consuming and that's without paint. Pantherman
Think I will wait to do any touching in until later as I plan to do the rest of the hull by brush. Pantherman
View attachment 124849View attachment 124850
Doesn't look bad at all from this end .Not too happy with the stripes, only myself to blame as I used a cheap masking tape that was the right size. It's gone in the bin with the other 4 reels of varying sizes.
I did bin it but thought later it might be OK for something, not sure what, but something. PanthermanDoesn't look bad at all from this end .
Just some touch-up here and there .
Did you really throw out the tape ?
I'd keep it around for at least just general tasks .
Got the main gun deck finished, it's a pity none of it will be seen when the top deck goes on.......... PanthermanNot too happy with the stripes, only myself to blame as I used a cheap masking tape that was the right size. It's gone in the bin with the other 4 reels of varying sizes.
View attachment 124862View attachment 124863
Done that thanks to your kind tip earlier. Had to adjust the deck position slightly. PanthermanNow dont forget to test dry fit the sides to be sure all cannons fit the holes.
Thank you. PMLookin' good Panther, you're doing her proud!!
Few more cannons and a bit more done on the old gal. PanthermanGot the main gun deck finished, it's a pity none of it will be seen when the top deck goes on.......... Pantherman
Thank you. I'm enjoying this rather more than I thought I would. Mind you, I haven't started the masts, sails or rigging.......Panthermanlove the color combo, impressive build![]()
Needle not included lol, i look forward to the rigging results should you choose to do itThank you. I'm enjoying this rather more than I thought I would. Mind you, I haven't started the masts, sails or rigging.......Pantherman
