Re: ISD "Avenger" [WIP]
Grendels said:
Thank you for the review. They have a few nice kits on their site, an I have been thinking about getting one or two.
You are welcome
I myself consider getting the Arvey Products Nebulon-B and Super Star Destroyer - they seem two very fine models.
Now on this Avenger
I've complete detailing the top part of the hull for now, ending detalisation on the "wing"-area around main turbolasers.
The engine piece was glued in place
The additional side-trenches from accurising kit were enough to use them for some areas of the upper structure
Then came the problems of lighting the bridge.
I've drilled two holes in order to give some light to the trash hatch on the bridge neck
Then made a big hole for a number of fibers that went through the neck piece and the upper structure as well
Same hole was drilled in the bridge detail, that I've made hollow with the help of a Dremell
So, now everything is ready for lighting
At last I've decided to make this model detachable, so I can for ex. paint it as a whole, then unassemble in 3 distinguished pieces and easily add fiber optics, or make some maintenance if I get a burnt out LED.
So I took these neodymium magnets...
and installed them into the two hull halves with the help of CA and Revell Contacta glues, epoxy and two component putty (I want the mounting points to be really strong)
This is my first try in making a model, that holds together on magnets, and I must say that the result has really pleased me a lot
Thanks for the interest, guys, some more to come soon
