I want to make a start on the perspex splash guards and have a couple of questions if anyone can help...
What thickness clear plastic sheet would look acceptable and best to work with?
I'm guessing the real splash guards were 10mm thick max, which would be just over 0.2mm in 1/43 scale.
I could make this simple and just use cheap clear plastic, or the ones that come with the kit, but if possible, I would like to use acrylic/perspex.
Acrylic sheet doesn't scratch as easy as the softer dolls house clear plastic sheet and also, I have glued clear acrylic/perspex in the past with the proper adhesive for it and the bond is invisible.
That was 5mm perspex though, which brings me to my next question....what is the thinnest acrylic/perspex sheet available?
I have searched 0.5 and 0.3 acrylic sheet, but the results seem to come up with PETG sheet.
I want the same stuff as what is normally available in 2mm to 5mm that's used for acrylic display cases for example.
I'm hoping to make the splash guards removable in one piece with the attaching arm.
I'm looking into using some photo-etch carrier frame (the sprue) for the splash guards metal mounting strip that runs along the bottom. If this works out, I may attach this brass strip to the model with a little gap for the clear panel to slot into.
