trekriffic
- Jan 6, 2012
Thanks for the nice comments guys. Yes, this is a lot of work and I'm really looking forward to when this build is done! It should make quite the display piece I think.
Today's progress...
Worked on a lot of little things today.
I wanted the launch bay doors to look like they interlocked so I cut 5 sections of thin styrene strip to 1/2" lengths and glued them to the edges of the doors staggered so they go together like woven fingers:
I did a lot of work to finish up the sensor dome which I now looks less like a ball and more like an array.
After drilling some holes and inserting some really small flat headed pins (delicate work) around the perimeter at the base of each facet of the rhinestone I drilled a hole thru the stem and up into the clear plastic of the rhinestone:
The entire array including the rhinestone was painted with Mr Surfacer. After it dried I drilled a round hole in the center of each facet to allow light to shine thru.
A 3 inch length of .5mm fiber was glued up thru the stem into the bottom of the rhinestone:
A nail set was used to make small circular tape masks for the holes drilled out of each facet:
The array was dipped in Future to seal the tape masks and, after drying, sprayed with Tamiya Bare Metal Silver:
I'm hoping when the array is inserted in the opening atop the bridge the fiber strand, which bends in the direction of the main high brightness LED, will transmit the light up into the rhinestone causing the ports in each facet to glow.
Next I took some aluminum tubing of the right diameter to fit over the barrel of the phaser projector and beveled one end with a grinding stone spinning in my dremel's flexi-shaft held in a Panavise.
Then I cut the metal tube in my mini cutoff saw and glued it to the plastic tip of the phaser projector:
It's a small thing I know but I think it's a nice upgrade over the simple kit part. The metal gives it more of the appearance of a gun barrel now.
Moving to the stern I made a cover from two thicknesses of styrene sheet and epoxied it to the slide switch that controls the launch bay lights:
The last thing I did was to mix up some AVES and fill in some major gaps in the stern and along the nexus where the upper and lower wingtips meet.
I also smoothed the seams in the forward part of the hull alternating between sanding sticks and my seam scraper. Then I covered the seams with Tamiya polyester putty and set the whole thing aside to dry for the night.
Comments welcome!
Today's progress...
Comments welcome!
