Thanks guys!!
Glad to have you guys along for the ride!! ;D
Another little update to keep me in the game here!! I managed to get the bogies and wheel underway. I have found more often than not, the mounting pins are pretty much useless on this kit and either should be removed, cut and sanded thinner or replaced with brass or styrene rod stock. I still thing the kit looks great but Mirror should probably think about investing more time in getting the mounting pins and hole to match up, Oh well!! Time to play...
First up was the rails to the bogies. There were a couple mold seams that needed to be removed on the top and bottom. Subsequently, the traversed over the molded bolts which as you figure are not always a fine time in the old coral to remove.
While the detailing is not too bad, the bolts Mirror added to these features should actually be hex -shaped and not round. Sine I needed to sand anyway, I chose to remove them all, sand and replace.
After a little surgery to add new bolts, it was time for another dry-fit.
Well, that is it for the moment. Time to switch gear and jump into the cab section; the floor and controls are next. So far so good. I might be in good shape by the end of the week on this thing!
Thanks for tuning in for a bit!!
