The Nylon Gag
- Nov 14, 2011
Re: NYLON GAG MK 1?
Evenin All,
Thank you so much for stopping by and leaving a comment guys, it really does motivate me to keep going.
So... rear cockpit hatch area bit.
Lets have a look, eyes down for a full house.
PIX
Made a door out of a trailer box and a round gun support plate with some other greeblies for the locking mechanism and a bit of PE on the side walls.
Added a square top beam to brace back from the seat assembly
Attached some control boxes to each side wall
Fabricated this half ring to fill the transition and support the side walls
Added the side walls and put these braces on the back side to strengthen the assembly
Fitted the half ring in position
Started filling in the over head are of the corridor
Drilled holes and installed overhead fiber optics for the corridor lighting
Also put two larger diameter fiber optics on the rear door, these will be attached to flashing LEDs.
Obviously these will be trimmed down after painting
Spent a few hours messing about with the wiring and finalising what goes where, the LEDs in the side pods
could be brighter but i want it to be subtle so maybe it will look better when its all assembled and i've cleaned all the holes out in the PE
I will be adding more details in the ceiling of the corridor next, overhead pipes and wiring, so stay tuned
Take care
Gag out ;D
Evenin All,
PIX
Take care
Gag out ;D
