Well, you probably thought that I sit around talking about building models, more than doing actual work on them
But here is another little bit of progress, and believe me, I actually have spent a lot of time on this step, since the last post.
I've finished masking and painting the windscreen! And when I say I spent a lot of time on it, I really mean it. This was my first time working with Parafilm, and I've learned some lessons.
For one thing, I probably wouldn't use it again on a small vacuform canopy such as this, at least, not in the same sequence. Cut from its carrier, the canopy is very flimsy; if it were more rigid, it would have been easier to lay a large piece of film over the entire sections, and then cut away the framing. On a styrene canopy, I think that method would have been relatively easy. I did try applying a large piece and cutting it on the work, but there just wasn't enough rigidity. If I were to Parafilm another vacuform canopy, I might apply it while the canopy is still on the carrier, then cut the carrier away.
As it was, I cut tiny pieces of Parafilm and applied them to the clear panels. I confess, I got frustrated with the windscreen, despite doing a little bit at a time, so as not to get bored. But applied in this way, the Parafilm is the fiddliest of all fiddly things in the entire fiddly universe. Fortunately, I'm blessed with a great brother, who gave me a third hand stand a couple of years ago, one of those stands with a cast metal base, a couple of alligator clips, and a magnifier. I stuck the windscreen in one of the clamps (which I wrap with masking tap, to protect the work), and worked carefully with tweezers and a plastic rod to attach each piece. Let me tell you, little 5mm squares and strips of Parafilm have minds of their own. But as I said, I got frustrated at one point, pulled of the film I'd applied, grabbed a brush and started painting. But that looked terrible. So, a quick spray of Easy-Off, a quick cleaning, and I started over.
Mind you, this was over a couple of weeks, a little bit here and there, cutting pieces, trying to fit them, re-fitting, cutting new, and on, and on, and on...
Anyway, one last push, and I declared the masking done. I shot the windscreen with OD (a different shade, argh! because I've run out of Tamiya AS olive drab), and, tonight, I've removed the masking.
So, after so much
Geschwaetz, here is what the canopy looks like:
and from the other side:
I can hear Quint, when Brody couldn't tie a knot--"Heh-heh, not too good, is it, Chief! Well, nuthin's easy the first time."
Actually, it's not as bad as all that. I've already done some cleanup; the bled paint comes off easily enough with a toothpick. It won't take too much longer to clean the rest of it off. And I had already planned on going over the clear panes, and the underside, with a weak ammonia solution, Windex, really, followed by Future brushed on, and touching up bare spots on the frames with a brush. I have a little scrap of plastic drying right now, for the mirror that Klibbe had on top of the windshield.
I'll probably use the Parafilm again, but for the next attempt, it'll be a styrene canopy, to see how that works.
I'm getting close to finished now, I can taste it. I attached some more bits, but I don't want to post any pics of the aircraft now, until I'm done. With another snowstorm on the way, I'll have some time to stay put this weekend.
Anyway, thanks for looking, sorry for running on, and always, comments/criticisms are welcome!
YbiC
Brad
