Question about 2-color LEDs: anode or cathode?
stevethefish
My name's actually not Steve
This week I ordered some 2-color LEDs. The middle prong is the cathode, and the two anodes are to either side. That would make them common cathode. But what would a common anode entail? One anode and two cathodes? What good would that do since it would power both colors at once, wouldn't it?
Those are just 2 LEDs in one fixture .
Power into the outboard anodes with a common ground at center .
current can only flow one direction thru a diode .
If it is the reverse then yes , both will always light to produce a specific color .
I think perhaps the difference is that common cathode is an either/or, whereas common anode can have both colors simultaneous. I'll buy some common anode and test the difference.
LEDs are light-emitting diodes, and a diode is an electronic component through which electricity can only go in one direction. In electrics, the anode is the side that electricity comes from, the cathode is the side it goes to
So, with two anodes and one cathode, the side of the LED that lights up is the one that you connect to the + side of the power supply. If you connect both anodes to the + (and the cathode to the −), I would think both colours of the LED will light up. With a switch in the cathode wire, you can turn both on or off at the same time, while with switches in the anode wires, you can turn them on and off independently.
OTOH, in an LED with two cathodes and one anode, you need one wire from the + to the anode and two wires from the cathodes to the −. The net effect will be totally the same, though: you can make one or both sides light up, depending on where you put the switch(es).
¹ Though remember here that electrons, which are what electricity actually is in a metal wire, go the other way — that is, they flow from the −-side of the power supply to the +-side.
Yes, I know the terms. But when I slipped a 2032 battery in between the prongs, I was unable to get both to light up as far as I could tell. It seemed to have a cancellation effect. I'll look at them again. I know what you're saying and it makes sense, but if there is no difference, then why build them differently?
